Has anyone Whipple Charged, or significantly upped the HP in their 242-LS?
A buddy of mine picked up a CHERRY 242-LS last Summer, with the 454/365 setup. He complains about the overall power throughout the power curve. I obviously suggested propping the boat, but also to look into a whipple setup.
Has anyone done this, or upped the HP significantly while staying naturally aspirated? What speeds are you guys seeing if so? Thanks!
I have a 1990 242LS that also had the 365HP setup and saw 54.5 MPH on GPS with a 23P 3-blade Mirage (non-plus model). Two years ago, I had a motor built. It is my 454 block bored 0.060 (496ci) wih Dart heads and intake, Holley 850 carb, MSD ignition, Stainless Marine exhaust, etc... It makes 615HP and about 620 lbs. of torque.
The best I've seen with this setup is 71MPH on GPS with a
27P Mirage Plus. I blew up the stock Bravo One the first year, but ran a Bravo X with Imco XR lower last year with no problems.
You have to put a huge amount of power to make these things go due to the hull design and weight.
Mine's now for sale!
[QUOTE=chewymalone;2822263]I have a 1990 242LS that also had the 365HP setup and saw 54.5 MPH on GPS with a 23P 3-blade Mirage (non-plus model). Two years ago, I had a motor built. It is my 454 block bored 0.060 (496ci) wih Dart heads and intake, Holley 850 carb, MSD ignition, Stainless Marine exhaust, etc... It makes 615HP and about 620 lbs. of torque.
Mine's now for sale
