fuel pump relay coil measurement >
Old 03-17-2009 | 07:23 PM
Default fuel pump relay coil measurement
I have measured the coil of the relay it is 85 ohm's, does the resistance need to be more on the coil . With 85 ohm's will this drive the ignition wire down, acting like a ground. Thanks for any input.
alecsammy is offline
Old 03-17-2009 | 08:01 PM
monstaaa's Avatar
sure aboutv the decimal.
monstaaa is offline
Old 03-18-2009 | 06:32 PM
Default monstaaa
Yes it is 85 ohms, very capable of reading a meter. If your saying it is a decimal off what should read .Thanks
ctuck0659
0
06-20-2007 07:08 PM
Biggus
13
04-25-2007 06:39 PM
MnHowardCat
2
04-23-2006 09:13 PM
magnum
6
04-09-2004 04:18 PM
Keith
0
04-28-2003 06:26 AM
