Drive Toe adjustment. >
Old 03-22-2009 | 07:55 AM
Default Drive Toe adjustment.
Getting ready to put the drives back on and was looking over some past threads, is the correct set up 1/8 inch toe in with the props turning out ? Props are bravo 4 blade 32's
laszlo01 is offline
Old 03-22-2009 | 10:58 AM
ACTIVESHACK's Avatar
I think I would check with Pat on that one.
ACTIVESHACK is offline
Old 03-22-2009 | 03:39 PM
What do you have yours set to ?
laszlo01 is offline
Old 03-22-2009 | 04:13 PM
Mine is set at whatever it was when the boat was built. That's why I suggested checking with Pat.
Old 03-22-2009 | 06:39 PM
slboatdrinks's Avatar
Good call.
slboatdrinks is offline
Old 03-22-2009 | 06:40 PM
Why would you have changed the toe bar?
Old 03-22-2009 | 06:51 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Due to the previous drives and setups, Laz's bar was not as it came from the factory.
Sydwayz is offline
Old 03-22-2009 | 06:53 PM
Ok then, measure yours.
Old 03-22-2009 | 07:43 PM
Just want to get everything back to stock set up, I understand that things where switched back and forth a few times so I figured if I put it back to factory specs that would be the best place to start. Does Pat keep the set up specs on each boat on record ? If it aint broke dont fix it but if it aint right put it back to stock is my motto. The drives are just about done and getting ready to refinish all the hardware so I figured I would get all the stock specs to insure the right set up. Want to make sure we run good at this summer poker runs.
laszlo01 is offline
Old 03-22-2009 | 07:45 PM
Yep, Pat's your man on this.
