Drive Toe adjustment. >
Old 03-22-2009 | 07:51 PM
Sounds like that may be the case, I will give him a call to ensure proper set up.
laszlo01 is offline
Old 03-22-2009 | 08:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I can't give out my secrets on Monsoon!
Sydwayz is offline
Old 03-23-2009 | 01:09 PM
I see how you are.
laszlo01 is offline
Old 03-23-2009 | 05:49 PM
R Addiction's Avatar
AT Cult Member #3
Originally Posted by laszlo01
I see how you are.
Brians got 496's not 525's....i see where he's coming from.
R Addiction is offline
Old 03-23-2009 | 05:50 PM
AT Cult Member #3
Not that theres anything wrong with 496's Brian
Old 03-23-2009 | 06:44 PM
ActiveThunder's Avatar
The theory is to toe it in an 1/8" and then the prop's torque will bring it back to zero which will give you an exact, perfect 0 degree drive setting.
Take a tape or tram and get it close. Don't lose sleep over it. Truth be told it won't effect a thing if it's in or out.
In a car the toe-in effects tire wear due to the fact the tires are 'skdding' over the pavement if too much or too little. In a boat, not the case.
Hope this helps.
ActiveThunder is offline
Old 03-23-2009 | 07:40 PM
Pat thank you, that backs up my understanding of the initial preload on the toe in, thank you for the clarification. There are lots of different view points on this set point and it is always good to hear it from the builder. I just really want to set it up the way it was ment to run so I am not chasing my tail. Things are coming along nicely and it should be ready in time for the summer. Will keep you posted.
laszlo01 is offline
CPPerformance
New Products and Member Discounts
15
07-24-2015 11:58 AM
SkiDoc
8
02-04-2006 02:46 PM
Quiet Storm
3
11-23-2005 11:20 PM
LAKESIDE RESTORATIONS
0
10-13-2005 09:41 AM
Freddie
9
11-30-2002 09:58 AM
