To much water pressure 509 big block >
Old 03-23-2009 | 08:52 PM
Default To much water pressure 509 big block
installed new offshore water pickup. 35 + lbs of pressure
looking for pop off of some sort to place in the block or inline from seapump. Anyone know where to buy reasonably priced
All ready blown head and intake gakets do not want a repeat
thanks
Steve303
steve303 is offline
Old 03-23-2009 | 09:10 PM
Is it a transom mount pick-up? If it is, file it down in small increments until you get the water pressure you want.
BenPerfected is offline
Old 03-23-2009 | 09:18 PM
What he said ,,,,he knows more then me anyways !!!!!
A picture of your waterpickup would be nice though ?!
Mine is at the transom and sticks out about 3/16 of an inch ,getting around 16 pounds on my 509 with SM seastrainer and reg. seawater pump !!! Which is plenty !!
DareDevil is offline
Old 03-23-2009 | 09:20 PM
Biggus's Avatar
I've had great results with the Merc water pressure relief valve.
Here's a thread on it.
http://www.offshoreonly.com/forums/g...ief-valve.html
Kurt
Biggus is offline
Old 03-23-2009 | 09:25 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Originally Posted by Biggus
I've had great results withthe Merc water pressure relief valve.
Kurt
I have used these and they work well
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-23-2009 | 09:41 PM
I can't post pic's here. Check this thread. Page 2. I made a pop off valve. 17 lbs at 36 - 3800, 20 lbs ate wide open 5000rpm.
http://forums.boatfreaks.org/showthr...water+pressure
Too much money for the merc plastic junk. My .02
Noise Pollution is offline
Old 03-23-2009 | 09:46 PM
johnnyboatman's Avatar
is there any way to install a ballvalve to lower water pressure. i know trimming the pickup works better can also let u pickup more speed. was just wondering if it works i put some on my innercoolers but havent tested them yet.
johnnyboatman is offline
Old 03-23-2009 | 10:00 PM
I think all the above works,,,but the real thing and right set up is to cut the pickup down !!!!!
Why would u add a trublefactor in a boat if ther is a easy way to fix it and make it right for ever ?
Old 03-26-2009 | 08:27 PM
Default water to high
thanks for the replies Will continue to file down, as speed increases so does water pressure.if that does not do it wiill make pop ff
steve303 is offline
Old 03-26-2009 | 08:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
A ball valve doesn't control pressure, it limits volume.
I installed the Merc relief valves on both of my completely stock motors after seeing over 35psi at cruise speeds. After screwing around for the better part of the summer trying different dumps, valves, different t-stat housings, I bite the bullet and installed the Merc valves. Now all is perfect!
US1 Fountain is offline
