Go Back  Offshoreonly.com > Owners Forum > Excalibur
Cracked stringers >
Cracked stringers
Cracked stringers
Old 03-25-2009 | 10:18 PM
Exclamation Cracked stringers
Help!! I just picked up 1981 27' excalibur! I have several issues that i need to address right away. Number one concern is that the engine mounting plates that sandwich the stringers look to be aluminum and have corroded to the point that the expansion of the plates have begun to crunch the stringers on both sides and resulted in bulging upward and cracks in both stringers. What material are the plates, what would corrode, and what is a good fix? thanks so much, Mike
manaze is offline
Old 03-26-2009 | 12:01 AM
They are aluminum !!! if there corroded u need to replace, engine out ,unbolt and rebuilt stringers ,since my quess is the core in them is rotten otherwise they should not get damaged from the plates !!
I know thats not what u whanted to hear ,but now is the time to do it right !! SORRY
DareDevil is offline
Old 03-26-2009 | 09:42 AM
Thanks DareDevil, I appreciate your time. I am not sure what the construction of the stringers are. I assumed sometype of 2X wood. I was planning on just unbolting engine mount plates one side at a time and glassing over stringer, gelcoat and replace with like stainless steel plates..? Sufficient? or much more involved? any input appreciated...MIke
manaze is offline
Old 03-26-2009 | 10:02 AM
That is just a band-aid. Stringers are wood and if they are wet they are most likely rotten.
Westcoast is offline
Old 03-26-2009 | 10:27 AM
spazboz's Avatar
I agree with these guys, the only right way to fix this is to just get it out of there and replace it. And be prepared for the worst, many times things will be worse than it looks from the surface in these matters.
Good Luck, Nick.
spazboz is offline
Old 03-26-2009 | 10:53 PM
Default Next Step
thanks all for your input. I will wait for the snow to let up here in SLC Utah and then take a few shots in the sunlight and repost to this forum for further consideration. thanks again...my first post...
ps..what a stunning boat...i am taking the plunge....Mike
manaze is offline
Old 03-29-2009 | 11:29 AM
Any pics of the boat ?
myscarab30 is offline
Old 03-31-2009 | 11:02 PM
Default pics
folks, is there an easy way to post pics of boat/stringers
thanks, Mike
manaze is offline
Old 04-10-2009 | 05:12 PM
[QUOTE=manaze;2833637]folks, is there an easy way to post pics of boat/stringers
thanks, Mike[/QUO
You have to be a payed member
Old 04-16-2009 | 06:07 PM
Jammin''s Avatar
There's an old 27' Excalibur sitting and rotting in the yard at the shop where my boat is. I can't get over they way I love the shape of it and the 31'. To my eyes, they are just right.
Jammin' is offline
