Water thru hull location >
Old 03-20-2002 | 06:26 PM
Question Water thru hull location
You guys with Shadows, Chris Cats, and other cats with similar bottoms. Where are your engine water thru-hulls located?
Mine are thru the sponson pads (flanges mounted externally), about 5" forward of the transom, about 3/4" long, and directly in-line with the drives. I tried shortening them about 1/8" and that caused a loss of water pressure. Doesn't seem like a great location (as far as "drag" and water to the prop is concerned).
Dueclaws is offline
Old 03-20-2002 | 11:41 PM
rbtnt's Avatar
I made mine flush and ground out some of the gelcoat and fiberglass to get the water presure back up. This was on a 28' Daytona.
rbtnt is offline
Old 03-21-2002 | 09:32 AM
I've had chris cats set up with transom mounted and thru hulls. The thru hulls were only about 1 ft from the transom. Cut at an angle. Front was flush with bottom, back was 3/8" long. Both setups were as close to the tunnel as possible.
Gary
Gary Anderson is offline
Old 03-21-2002 | 09:38 AM
From some off-board discussions, it seems that the externally mounted flange might be causing turbulence, which makes it necessary to have a longer tube. I'll try a new intake with an internal flange. Thanks to all.
Dueclaws is offline
Leathl_WS6
Excalibur
7
01-12-2007 04:30 PM
Leathl_WS6
2
12-13-2006 09:49 AM
Leathl_WS6
12-12-2006 04:28 PM
US1 Fountain
5
04-07-2003 11:11 PM
Elite Marine
Pantera
1
10-22-2002 09:45 AM
