Livorsi tachs acting strange - need help please >
Old 04-05-2009 | 05:15 PM
Default Livorsi tachs acting strange - need help please
So, I just had new motors put in my cig. Went from the stock 525sc's (which were 454 blocks) and went to 502 blocks and running TBS blowers at 5 lbs of boost. I am in my break in period right now and I noticed that once the tachs reach 3800-3900 rpm's, they start fluttering and freaking out; actrually going backwards. Its not the motors - they sound and run great. Does this sound like an electrical issue? Ground maybe? I am kind of stumped. The tacjs worked fine before the rebuilds, but now, they work up to 3800 and freak out. What should I be looking at? modules? wiring? grounds? The GPS speedo also does not work. Any feedback or thoughts would be much appreciated. Mark
eichhoma is offline
Old 04-05-2009 | 05:22 PM
I said it many times ,,,BUY GAFFRIG , Livorsi sucks !!!!
DareDevil is offline
Old 04-05-2009 | 06:38 PM
Elite Marine's Avatar
Nice approach. I think this issue was covered in many other threads. I'm sure all the manufacturers - Cigarette, Outerlimits, Hustler, MTI, Skater and others would only install the absolute worst gauges in their product - Livorsi.
The only thing I like about the Gaffrig gauge is the glass lense. I dont like any other aspect of their product, but I still wouldnt say they suck. But then again I was probably just brought up properly.
If thats your method of marketing, I suggest you revisit Marketing 101. Promote your product without slamming the competition.
As far as the issue here, there was or is a definate change in what the tach is seeing or getting feedback. If you want to send the tach in to get it tested, let me know and I'll take care of it. I suggest swapping tachs to try it first. If I can be of further assistance, please let me know.
Kirk
Elite Marine is offline
Old 04-05-2009 | 10:49 PM
I would have to guess its in the wiring. Did reuse the TB IV's or go with new ignitions??????
Griff is offline
Old 04-05-2009 | 10:56 PM
Kirk
KIRK,KIRK,KIRK,,,,how many times should we argue about this.
THE ONLY REASON WHY ALL THE BIG BOAT COMPANYS USE LIVORSI NOW ,,IS BECAUSE LIVORSI LIED ABOUT GAFFRIG AND EVERYBODY THOUGHT ITS ONE AND THE SAME !!!!!
THE BEST GAUGE IS GAFFRIG or NORDSKOOK and u know it.
Old 04-06-2009 | 06:16 AM
Stayed with the TB IV's and have the v6m modules.... I was kind of assuming it has to be wiring too, both worked just fine when the boat was brought in for the rebuilds. I just dont know if they share a ground or what is going on up under the panel. any suggestions?
eichhoma is offline
Old 04-06-2009 | 07:54 AM
BillR's Avatar
OSO Moderator
I have heard that is due to slight moisture in the gauge itself.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-06-2009 | 08:21 AM
Would that stand to say they could dry out and the problem would go away? Or should I send these to Livorsi to be tested? It just seems strange the problem appeared right when engines where swapped and they worked just fine. The boat never sat outside, or got wet this winter. And with the gps speedo not working as well (both worked fine when boat was brought into shop) It just seemed to me that it might be related to wiring..... any other suggestions? I really appreciate the feedback.
eichhoma is offline
Old 04-06-2009 | 10:18 AM
Brad Zastrow's Avatar
I think you have a bad ground or loose sender wire somewhere. Pull the plug on the wiring harness by the engine and spread the prongs and clean if needed. Check for loose ground straps or even not connected wires on the engine. I say this because you just installed the engines and now you have problems. I doubt you have gauge issues. The engine can run fine but if the ground to the dash is not hooked up or loose...
Brad Zastrow is offline
Old 04-06-2009 | 12:18 PM
Check the grounds on the modules. They have a black ground wire and the module case/mounting plate also needs to be grounded.
Griff is offline
