hydrahoist questions
Old 04-07-2009 | 02:31 PM
Default hydrahoist questions
i am about to buy a 2000 9000B Lift in good shape for 3k. How hard will it be to install in a lagoon? I have boats in frt. and behind me so i might have to put the back on a whip or something to pivot the entrance? How long does it take to go up and down? Thanks
brian18330 is offline
Old 04-07-2009 | 05:56 PM
BraceYourself's Avatar
What I've learned about lifts is you really have to spend a ton of time thinking your install through. And even then it usually ends up changing. Once complete and done right you'll be glad you did it. Was just tweaking mine this past weekend in 37 degree water. Brrrrrrr.
BraceYourself is offline
Old 04-07-2009 | 06:14 PM
ReggieRaft's Avatar
How deep is your area for the hoist ? Sounds like pushing out the stern then lowering the thing, then raising it to pull it back in will be a pain in the assss. Get a lift type.
ReggieRaft is offline
Old 04-07-2009 | 06:52 PM
H20 Toie's Avatar
I have a 20k lift for the 40' formula and it takes less than 5 min either going up or down.
I had it setup and installed and glad i did, it looked like a pain to do myself.
H20 Toie is offline
Old 04-07-2009 | 06:57 PM
Screw IT's Avatar
Wow,less than 5 minutes?????
Screw IT is offline
Old 04-07-2009 | 07:50 PM
In germany there is a company,,,never seen one like that over here ,but its AK lift and only 3.5 feet water needed up to 30000 pounds hydraulic has a u shaped dock around it is free floating and galvanized steel with anodes for either salt or freshwater appl. more money then Hydrohoist or similar but tricked out like hell.
I actually had 1 in germany.
DareDevil is offline
Old 04-08-2009 | 10:36 AM
Front and rear must be secured to dock. If not it will sink to bottom and will not work right. back has to sink before front or it gets air locked and wont sink .
tms1155 is offline
Old 04-08-2009 | 10:38 AM
Stormrider's Avatar
JC Performance Engines
Airdock may be an option.
www.airdock.com
Stormrider is offline
Old 04-08-2009 | 10:59 AM
BeakBoater35's Avatar
If the stern is not lowered before the bow the boat/lift will roll. Don't ask me how I know this!
BeakBoater35 is offline
Old 04-08-2009 | 11:56 AM
H20 Toie's Avatar
So true
H20 Toie is offline
