starter problem >
starter problem
starter problem
Old 04-07-2009 | 04:50 PM
Default starter problem
Sometimes I turn the key and hear just a click, this might happen 4 or 5 times before the starter will turn over. sometimes I get in, turn the key and away we go. Any ideas? I was thinking of just tearing down the starter and giving it a good clean up and some new brushes.
Thanks for the help!
misskristy is offline
Old 04-07-2009 | 04:55 PM
Sounds like a weak solenoid to me. Although brushes & that can't hurt.
pwam1 is offline
Old 04-07-2009 | 07:02 PM
Vinny P's Avatar
I hate the winter!!
Dont forget about the additional solenoid that is wired into Merc starter circuits. See part # 5
http://www.mercruiserparts.com/Show_...AND+COMPONENTS
Vinny P is offline
Old 04-07-2009 | 07:48 PM
this is a 1988 do i have 2 selonoids?
Old 04-07-2009 | 09:12 PM
Yes, its called a slave solenoid.
1BIGJIM is offline
Old 04-07-2009 | 09:19 PM
starting problem 1994 cig top gun does it have a slave solinoid and where is it thanks for any info
joepequa is offline
Old 04-07-2009 | 09:53 PM
johnnyboatman's Avatar
check the cables, and grounds
johnnyboatman is offline
Old 04-07-2009 | 11:21 PM
Slave selonoid (#5) on mine went bad, changed it, now all is good.
Kidnova is offline
Old 04-08-2009 | 04:45 AM
Mr Gadgets's Avatar
Charter Member #601
Put a volt meter on the + terminal on the starter and check what voltage you see there. If it is significantly lower (1v) than battery voltage, you have a connection problem. Either one of the soleniods could be dropping voltage or a bad connection or a bad ground???
If it wont do it when you have the voltmeter along, always carry one and you will never have the problem again..
Mr Gadgets is offline
