Pressure Testing a Bravo
What is the proper procedure for pressure testing a Bravo XR drive? I have a new XR upper that I will be mating to a 02 lower. I have new nuts and orings to assemble them, but am wondering how to pressure test it to ensure everything sealed.
Thanks!
Thanks!
You'll need the proper lower unit pressure tester. You'll have to mate the two halves together then pressure test to 15lbs. Leave i alone for at least an hour - I leave mine overnight when I can. If you discover you have a slow leak you'll either need to spray it down with soap and water or do like I do and lay it in a kids sized swimming pool and chase the bubbles......no chit...it works.
I've been using the Steven brand tester for years ..
I built my own tester, and I have a fittings (SS) that converts from the 3/8"-16 thread to 1/8" pipe, available. I put a tee fitting on that and gauge on one end and shrader valve on the other, of the tee. 15lbs
24hrs is a good test. Should not leak any. If temp changes then psi will a little bit maybe 1/2 lb..
When I have a leak I have a tank that I dunk it in. So much faster to find the problem area, as mentioned above.
I have had found at times, a leaker and found a problem with the hose to the gauge or the shrader valve stem was loose, so don't go tearing it down till you find the source of the leak.. I tell you this from experience..
But as the replys above indicate.. PSI for over night and you will know. Usually it is the orings between the upper and lower, or a nick in the area where they are suppose to seal.
Hope this helps.
Dick
Hope this helps.
Dick
You also should do a vacuum test and don't forget to rotate the shafts while the drive is under pressure/vacuum. Here's the pressure/vacuum gauge i use.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
I sell them for $189.00 Call 302-521-0123
Thanks, Bill
Thanks, Bill
[email protected]
302-521-0123
[email protected]
302-521-0123
