Help-Sea Strainer Install on Merc 496HO
I know where it should be located versus the water pump etc. However the steel cored hose required on the suction side of the water pump is not at all flexible and does not come with molded in bends like radiator hose. So I am curious how and where in the boat one would plumb the sea strainer to accomodate that fact and tap into the water intake hose between the transum and the water pump on a Merc 496HO/Mag closed cooling system which also has an air pressure actuated sea water drain valve assembly hooked up to the water intake hose in that same location. It is a busy location
Has anyone ever done it?
