Hydraulic Steering - do you keep the tiller arm? >
Old 04-12-2009 | 06:39 PM
Question Hydraulic Steering - do you keep the tiller arm?
G'day all,
Just looking at the transom assembly while I've got the motor out. When you've got full hydraulic steering (IMCO), is there a need for the tiller arm from the old set up? Can I remove it or more importantly should I?
(Mind the wiring etc in the pic, I've cleaned it up a lot since then!)
Attached Thumbnails Hydraulic Steering - do you keep the tiller arm?-tiller.jpg
Ghostrider is offline
Old 04-12-2009 | 06:43 PM
If its in the way just cut it off. That is how fountain rigs there boats.
Westcoast is offline
Old 04-13-2009 | 09:38 PM
I just left mine.
Sledge Hammer is offline
Old 04-14-2009 | 06:58 AM
Thunderstruck's Avatar
The arm also functions as a spacer on the upper swivel pin for the gimbal ring. You can cut it off but you need to keep the spacer function intact.
Long time cult member.
Thunderstruck is offline
Old 04-14-2009 | 05:03 PM
Excellent thanks!
That's all I needed to know.
I think I'll leave well enough alone, especially now I know it's a spacer etc.
Cheers!
Old 04-15-2009 | 12:49 AM
articfriends's Avatar
I trimmed mine off a few years ago then sanded the edges/re-painted it before re-installing it. Not on is it a spacer but it clamps on the swivel pin,Smitty
Attached Thumbnails Hydraulic Steering - do you keep the tiller arm?-boyne-054.jpg   Hydraulic Steering - do you keep the tiller arm?-boyne-055.jpg
articfriends is offline
Old 04-15-2009 | 12:52 AM
I also cut the ears off then trimmed the inner transom plate where the cable attached (in your pic the drive lube bottle is next to them) to un-clutter the engine compartment,Smitty
Old 04-15-2009 | 03:52 AM
Oh yeh! I hadn't thought of that, Good Idea!
I may just do that now, thanks!!
Old 04-15-2009 | 03:55 AM
That sounds interesting! Do you have a pic of the earless transom plate?
MadMat is offline
