Stock Rochester carb Q's >
Old 03-22-2002 | 01:36 PM
Jayl13's Avatar
Default Stock Rochester carb Q's
What does the stock Rochester Qjet carb flow ???
How many CFM
Dont want to over carb this thing
1990 454/330 Mercruiser on a peanut NO rise manifold with peanut heads
Thanks to all that reply
Jason
Jayl13 is offline
Old 03-22-2002 | 05:20 PM
Stock Q-jets flow 750 CFM @ 1.5 "Hg. Like all carbs, they will only flow what the engine can draw. The small primaries and the secondary air valve will keep your low end snappy, so don't worry about over carbureting. You can run the same carb on a high rise spread bore oval port intake, just grind the heads to smooth the transition to the peanut port. I did this on a 7.4 L 300 HP 454, added the 454 Magnum cam and picked up 5 mph.
tomcat is offline
1bagger
Northeast US
0
08-16-2007 04:18 AM
1bagger
Great Lakes and Canada
0
08-15-2007 09:00 PM
IHTFP
2
02-20-2006 08:44 AM
ragtop409
2
09-16-2002 01:56 PM
nofreeboard
3
08-13-2002 08:05 AM
