Spark Plug Change >
Spark Plug Change
Spark Plug Change
Old 04-18-2009 | 06:28 AM
gripit's Avatar
Default Spark Plug Change
How often do you change your plugs? Once a year? Every other year? Other? Thanks
gripit is offline
Old 04-18-2009 | 07:28 AM
Pwrbt33's Avatar
Usually if the engines are large and have idling issues and alot of hours they get replaced every year. If the engine is mild with nicely set up carbs and ignition you can usually go every two.
How has the boat been for you? Are you done doing upgrades?
John
Pwrbt33 is offline
Old 04-18-2009 | 07:42 AM
gripit's Avatar
John,
Whats up my man! I miss you down here on the island! Boats doing good, knock on wood! I did the top ends of the motors a couple years ago and over the winter, I was working on new upolstry for the cockpit. Its always a work in progress!! What plugs do your reccomend for my setup? Dart iron eagle heads on 454 with 750 carb with thunder bolt? Thanks
gripit is offline
Old 04-18-2009 | 07:46 AM
Hey Gripit
One thing you want to watch out for is the salt air and leaving those plugs in two long. If you try and go a couple of years you may end up with a couple of them that arent so easy to remove. I always use the old plugs to fire it up in the spring and burn the crap gas out then fresh plugs for the new season. Hope this helps
GoFastSonic is offline
Old 04-18-2009 | 02:09 PM
It depends on the engines.
Griff is offline
