Bennet trim tab ?
Old 04-19-2009 | 06:49 PM
Default Bennet trim tab ?
I have bennet 12x12 trim tabs on a 29 footer. i was wondering if i could upgrade to the 12x16 bennet tabs by just knocking out the hinge pin and swaping out the trim tab plates, or do i need to change the whole trim tab and and hinge plate that is mounted to the boat?
PQCRAZY is offline
Old 04-19-2009 | 07:20 PM
I will post some pictures of what you need you will be impressed!
pq man is offline
Old 04-19-2009 | 07:22 PM
I believe you have insta trim 12x13 tabs not Benetts,
insta trim offers 12x16 plates that comes with the hinge plates for around $400.00 but the problem is you still have the slow moving cylinders.
Look at your buddys boat across the street so you get a idea of what to do!
boatnt is online now
Old 04-19-2009 | 07:43 PM
ChristianGott's Avatar
most likely, yes..people swap 280 k-planes for 380's frequently, just the plate...measure the mounts, angles and the length of the rams for the longer setup...if it looks good, it probably is...be sure to check that your drives won't nip the inner edge of the tab... if you think they will, just cut the corner off...your tab will still work fine...
ChristianGott is offline
Old 04-19-2009 | 07:51 PM
Let me help you out
Attached Thumbnails Bennet trim tab ?-sidewinder-004.jpg   Bennet trim tab ?-tabs-004.jpg
Old 04-19-2009 | 09:18 PM
Boatnt .... i thought that insta trim was made by bennet tabs ?
PQCRAZY is offline
Old 04-19-2009 | 09:22 PM
Easy there pqman i think it was just a year ago you could not spell twin engines and nowz u gots them
PQCRAZY is offline
Old 04-20-2009 | 06:39 AM
No,two different tab companys
Old 04-20-2009 | 08:37 AM
Now I can even spell BIG BLOCKS
pq man is offline
Old 04-20-2009 | 05:18 PM
Thanks for all the input
PQCRAZY is offline
