Bravo 1 Drive Oil Question >
Old 04-20-2009 | 12:47 AM
Default Bravo 1 Drive Oil Question
I just had (2) fresh motors built, 572's to be exact and I'm going with a different oil set up from a company called Pure Power (www.gopurepower.com) - The owner Kelly is a oil specialist and he suggested to use his 15W40 which has more zinc than the competitors - he also said I wouldn't have to change my oil (after running hard) till at least 50 to 75 hrs - possibly even a 100. I already have his oil filters on my application (which are incredible) so I went will his oil as well.
This is my Bravo 1 question - he also carries a gear oil for the drives which is SAE 80W/90 which has GL-5 - would you use another manu drive oil or would you continue using mercury drive oil?
What's your suggestion?
whtnordic is offline
Old 04-20-2009 | 06:02 AM
How much more zinc than the competitors?
Ken
minxguy is offline
Old 04-20-2009 | 09:42 AM
Not exactly sure - I can contact him and see but I did find out that the higher the TBN reserve, the higher the zink count - competitors have a 7 to 9 TBN and he has a 12-14 TBN (Total Base Number).
I'm not on here to promote his product - I really want to know who on here has used it or has any experience with oils....
This guy really knows his **** and he has his product in all areas of speed and military use....
Old 04-21-2009 | 06:48 AM
TBN stands for TOTAL BASE NUMBER. This for the neutralizing of combustion acids that end up in your oil.
The only thing I see is todays fuels have very little sulfur in them, so the TBN plays a much less important role than it did back in the days of high sulfur fuel.
TBN was really a diesel issue as the diesel fuel for years back had a lot of sulfur. The auto industry "picked up" on TBN as a marketing tool but it really has no relevance in a gas engine.
TBN is based on calcium, not zinc.
I my opion, TBN in modern engines with moden day fuels is a moot point.
Hang your hat on something else.
Ken
minxguy is offline
