Cam specs?
Old 04-20-2009 | 01:58 PM
Default Cam specs?
i have a 1993 600 sc and was wondering what the cam specs are.
thanx!!!
FIXX is offline
Old 04-20-2009 | 07:11 PM
Default mrfixxall
I guess nobody knows?
FIXX is offline
Old 04-20-2009 | 09:27 PM
Smitty's Avatar
Not a common motor. Keep checking back. Somebody will know.
Smitty is offline
Old 04-22-2009 | 11:56 AM
Default mrfixxall
thanx smitty...
BUMP!
FIXX is offline
Old 04-22-2009 | 12:09 PM
This is all that they give in the merc hi perf manual.
Valve lift .5593".....both intake and exhaust
Duration @ .050 300* both intake and exhaust
Lobe lift: .329"
Hope that helps.
JaayTeee is offline
Old 04-22-2009 | 12:22 PM
Default mrfixxall
Lobe lift: .329"
Hope that helps.
When i talked to merc they told me,
@.051 the liiI & E was .359
and the duration was @.050 I .300 & E .300
i assune the centrerline is 114 or 116 deg..
thanx!
FIXX is offline
Old 04-22-2009 | 12:28 PM
thanx!
Do you mean lobe sep????? Probably 114.
Griff is offline
