Hull number locations
I'm looking into a early to mid 80's scarab 38. The owner says the hull numbers could not be located on the rear of the boat. Would there be any other locations for the #'s other than the rear?
On our old 1984 38' Scarab the HIN was on the outside transom below the swim deck. I can't remember exactly when HIN's were required. If you can't find it there I would suspect that it was filled in prior to a paint job, or it may be a stolen boat.
Either way, caveat emtor.
Good luck.
Good luck.
Good luck.
Good luck.
