TRS Outdrive Shower's >
Old 04-27-2009 | 10:44 PM
spazboz's Avatar
Question TRS Outdrive Shower's
One of the boats I am working on right now has TRS drives on it and the upper gear-case's are getting chalky every usage. I found this drive shower here:
http://www.cpperformance.com/detail.aspx?ID=527
Although the title describes it as being for TRS drives, the description states it is designed for a Bravo Upper.
Does anyone on here have drive showers in stock for TRS drives, or know where I can find them?
Nick
spazboz is offline
Old 04-27-2009 | 11:06 PM
c_deezy's Avatar
Looks like it should bolt onto the lifting eye on the top of the TRS case. Call CP and ask them, they are usually very helpful.
c_deezy is offline
Old 07-06-2009 | 12:49 PM
Biggus's Avatar
TRS drives have an oil pump that circulates the lube very well. Since the lower gear case is constantly submerged, they really don't have a need for a drive shower.
Biggus is offline
Old 07-06-2009 | 01:09 PM
fireboatpilot's Avatar
RIPSTA Racing Team
To be on the safe side I run showers on everything I have. I had TRS drives on my 30' Scarab and they do heat up and get chalky like you described. I might have a pair of showers still lying on the shelf. I'll check, I think their the Simrex style rigid tube. Check with me near the end of the week if you can. I'm not at home till Friday.
fireboatpilot is offline
Old 07-06-2009 | 02:40 PM
oreo11zeus's Avatar
Default Trs
Good point Biggus -
oreo11zeus is offline
Old 07-06-2009 | 02:42 PM
oreo11zeus's Avatar
Nick
These work well on TRS - www.brunsmarineperformance.com
Old 07-09-2009 | 08:38 AM
cig28's Avatar
if it has th merc trans u can use the water that goes through the cooling tube in the trans and use a water dump out the transom and face it at the top of the drive. that how i run it on my 20 ft cigarette and it works great with plenty of water volume . they also recommend dumping water overboard for better cooling in those transmissions.
cig28 is offline
