Innovate LM1 or LM2 >
Innovate LM1 or LM2
Innovate LM1 or LM2
Old 04-28-2009 | 08:39 AM
Ken N's Avatar
Arrow Innovate LM1 or LM2
Looking at Innovate LM1 and LM2. What i have is a single 502 MPI Which one it the pest for me?.
Ken N is offline
Old 04-28-2009 | 10:10 AM
Rookie's Avatar
I got a good LM1 off of e-bay for $100. I put 4 bungs and plugs in my pipes (twins). I just moved the O2 sensor to each pipe to read each bank. Once your dialed in you shouldn't have to be messing around anymore.
Rookie is offline
Old 04-28-2009 | 11:08 AM
blue thunder's Avatar
I bought a new LM2 last yr off jegs. The firmware was out of date when I recieved it so I had to figure out how to get that update 1st. After that, the a/f part worked fine but I was never able to get the rpm to work. I've done everything suggested on thier help site, still no good. The reason I got the LM2 was I wanted the data logging capability. Without rpm there is not data logging so I would have been better off with the LM1.
blue thunder is offline
Old 04-28-2009 | 12:05 PM
Rookie's Avatar
Innovate hasn't helped you on that? I heard that was one of the +'s to going with innovate was their customer service was great. thats an F'n bummer
Rookie is offline
Old 04-28-2009 | 04:28 PM
is there extra wires you have to hook up ,,,so it will read rpm,,dont they have a hook up for the plug wire,,so u can read rpm
TWIN-SPINS is offline
Old 04-28-2009 | 05:27 PM
It's been since last summer since I tried to get the rpm to work so I don't remember the specifics just now. I do know I did everything they said including wiring in a variable resistor which did not work. I used to go on the forum but after a while the help diminished and there were still problems. I may give it another go this summer but in hindsight, the a/f reading is what I was after and the LM1 does that.
Old 04-29-2009 | 01:44 PM
Rage's Avatar
I had a problem with the LM1 (plus the seperate RPM converter required to read/log rpm) after a period of time/use. I called their tech support and after trying what I was told that confirmed the unit was not working I received a RM number, returned unit to Innovate and they sent me a working unit no charge. No problem since. My unit plugs into the tachometer feed wire from the ECU for the rpm signal. They were very helpful but you need to call.
Rage is offline
Old 04-29-2009 | 04:18 PM
Good suggestion, I may due that depending on how well my new engines cooperate this season. Thanks.
I might add that I feel very confident in the a/f readings which is most important when picking a meter. I would buy innovate again simply because of this, the data logging is secondary.
Old 04-30-2009 | 11:34 AM
Rage's Avatar
I think it was Ford Muscle Car Magazine that did a test of the various A/F meters. Some were really inaccurate that cost as much or more than the LM-1. The LM-1 accuracy was amoung the best regardless of price. They stand behind their product with tech support and service. A no brainer.
Rage is offline
Old 04-30-2009 | 11:52 AM
That's why I bought it, that test. I had to richen significantly from the meter I was using after getting the LM2. Upon teardown this winter the a/f tune was right where I wanted it based on coloring. If I remember right the innovate is accurate to +/- .1 a/f, the others were as inaccurate as +/- 1.0a/f
