Crockett Marine Small Block >
Old 04-29-2009 | 06:41 AM
Michigan Mad Man
Default Crockett Marine Small Block
THIS IS A 434CI 9.4 TO 1 that runs on 91 octane pump gas. We built 2 of these for Furniture Row Nascar Team going in their 32 Sunsation.
http://www.youtube.com/watch?v=X-pVkY2eJoA
TylerCrockett is offline
Old 04-29-2009 | 07:07 AM
tyler can you give us some more info on the motor??
cam lift, what heads and other parts. thats 1.46 hp per cube which is really good. plus its making alot of torque.
really cool project, its good to see an engine builder thats working to make hp with just a motor and no blower
skaterdave is offline
Old 04-29-2009 | 11:38 AM
Michigan Mad Man
We used the SB2 Nascar heads that they do not use because Nascar went to the RO7 engine. I had a 650 lift cam ground on a 112 center and used the FAST fuel injection. I started with a Dart block with a .325 raised deck and a .391 raised camshaft and had Dart machine the SB2 lifter bore spacing in the block. We welded the injector bosses into the stock Nascar intake and used a 2000cfm throttlebody. Winburg made our 4.000 stroke crankshafts and we used the 6.200 long rods they ran in their car engines. I lowered the compression to 9.4 so we can run on 91 octane fuel.
Old 04-29-2009 | 11:43 AM
Gary864's Avatar
Sure sounds like a nice package.
Gary864 is offline
Old 04-29-2009 | 11:58 AM
littledcsrodshop's Avatar
Thats impressive !! Congrats !!
littledcsrodshop is offline
Old 04-29-2009 | 11:59 AM
outriggers's Avatar
I always liked the idea of big cu. small blocks, especialy for a 28' with twins. Nice...Doug
outriggers is offline
Old 04-29-2009 | 12:09 PM
How much weight do you save over a big block?
Wildman_grafix is offline
Old 04-29-2009 | 12:27 PM
Wink How Much Is That Doggie In the Window??
As I always say, "Nothing is impossible it just COSTS MORE!"
Nice job Tyler!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 04-29-2009 | 01:19 PM
that motor kept makeing hp until 6800rpm even if you rev limit the motor at 6000rpm 722hp. you still have grate power
very impresive
mike
mikebrls is offline
Old 04-29-2009 | 02:19 PM
Gary864's Avatar
Ok Sounds great, Weight savings, Great HP. What is the down side? If you have enough torque you should be able to spin the same props as a Big block. Help educate me. In my limited knowledge I do not see a down side. Why would you not run a small block? Maybe the CG woould be off? But I would think if you build it from the start then you can set ip up for the small block. Heck I spin my big block to 6,000 anyway.
Gary864 is offline
