What's the oil capacity of 454 MAG MPI? >
Old 04-30-2009 | 11:25 AM
Default What's the oil capacity of 454 MAG MPI?
It's a 2000 model, 385 HP, stock pan. I'll be pumping it out and changing filter.
boater454 is offline
Old 04-30-2009 | 12:07 PM
When you pump it out, it will take about 7 qts with a filter. Total actual capacity is 8qts.
Griff is offline
Old 04-30-2009 | 12:49 PM
Smitty's Avatar
I second that at 7 qts.
Smitty is offline
Old 04-30-2009 | 04:02 PM
Ok Thanks so much. I knew I'd get a quick answer on here. I tried searching for about 15 minutes but couldn't find it.
