Gimble bearing replacement >
Old 05-02-2009 | 05:03 PM
Default Gimble bearing replacement
Have you ever replaced the Gimble bearing/u-join bellows and if so, do you reccommend doing this yourself or having it done by a professional?
tebics910 is offline
Old 05-02-2009 | 05:42 PM
seafordguy's Avatar
That is going to depend on your skill level as well as your bank account level.
This was the first "job" I ever did on my boat, and i did it myself. It is a good starting point for learning your boat, and I would recommend it.
I had a couple posts in this thread that might interest you - some insight from an amateur.
http://www.offshoreonly.com/forums/d...questions.html
seafordguy is offline
Old 05-02-2009 | 06:03 PM
Thanks im going for it
Old 05-02-2009 | 09:33 PM
I heard your not very good with your hands and you'll screw it up..... I COULD DO IT IN 1 OR 2 HOURS.
plumb crazy is offline
Old 05-03-2009 | 09:18 AM
hoozeyurdaddy's Avatar
replacing the bellow is onething, the gimbal is something else, there are several special tools involved that you can't do the job with out, and if you try to improvise you could cause more issues than you want.
hoozeyurdaddy is offline
