chalky NXT drive???
Old 05-13-2009 | 01:07 PM
Default chalky NXT drive???
saw vee (won't post what boat out of respect for owner) with a chalky nxt drive last week. He's got 700's with nxt's. I didn't think these drives would do this. Any one got any info on why that would have happened? the guy use the wrong gear lube?
dbhammer is offline
Old 05-13-2009 | 01:12 PM
BrettM's Avatar
Offshoreonly Advertiser
Commercial Members
I have never seen any build up on NXT's. I wonder what is causing it???
BrettM is offline
Old 05-13-2009 | 01:46 PM
glassdave's Avatar
Neno the mind boggler
lack of proper care?
08 OPA High Points Champion
glassdave is offline
Old 05-13-2009 | 01:56 PM
thats what i wonder. the guy doesn't beat the crap out of the boat. obviously overheating but i thought these dry sumps prevented that.
dbhammer is offline
Old 05-13-2009 | 02:45 PM
glassdave's Avatar
it may not actually be overheating. Other drives having an external cooling system like the aftermarket Bravo ones keep the case pretty clean because of the constant water flow on them. Pending on what water this boat is in it may not take much to chalk it up with just a little heat.
Old 05-14-2009 | 09:31 AM
interesting. boat only in fresh water so far from what i know. just wanna make sure it doesn't happen to mine thats why i asking!!
dbhammer is offline
Old 05-14-2009 | 09:34 AM
offshoredrillin's Avatar
could be a number of things, depending on the mineral content of the water, each one will solidify at different temps, obviously there is some heat there, usually its a lime or calcium style. see whats in that area, ask around or check with a local water guy to see what is in the water in the lake.
offshoredrillin is offline
Old 05-14-2009 | 10:19 AM
RACEFUEL !!!!
DareDevil is offline
Old 05-14-2009 | 03:28 PM
2112's Avatar
I have had this happen on several Bravos. Some never saw salt water. All had showers. I attributed it to heat affecting the paint.
BTW. Salt Away takes it off nicely and keeps the black paint looking brand new.
2112 is offline
