Boost referanced carbs >
Old 05-14-2009 | 09:01 PM
Default Boost referanced carbs
Can I use boost referenced carbs on a na motor? If so what would I do with the reference port ,Hook it up to manifold vacuum?
dennis r is offline
Old 05-15-2009 | 06:25 AM
should work fine, still signals the power valve...Rob
ezstriper is offline
Old 05-17-2009 | 01:56 PM
ttt
dennis r is offline
Old 05-17-2009 | 05:15 PM
Check the jett sizes if they sat on top of blowers, they will probably be larger in the primaries and secondaries than you will want in NA motors....
eichhoma is offline
