What material to use for cabinet?? >
Old 05-18-2009 | 03:59 PM
Default What material to use for cabinet??
I need some help with this!!
I want to remove one of my couches and replace it with a cabinet topped with some sort of counter top along with a sink.
Anybody know what type of material would be the easiest to work with and finish?
Can plywood be painted to withstand the peeling and blistering?
I'm lost on what to use...
verbi69 is offline
Old 05-18-2009 | 09:23 PM
Thumbs up
i would use standard B/C plywood, (put the B side out) prime it and paint it or cover it with formica.... or vinyl to match your interior. good luck.
poiuy10 is offline
Old 05-19-2009 | 06:43 AM
rchevelle71's Avatar
Whatever you use, try to make the total weight similar to the couch you are removing, dont want to upset the balance.
rchevelle71 is offline
Old 05-19-2009 | 07:57 AM
Thanks guys.. I think I will go the plywood way....
Thanks!!
verbi69 is offline
Old 05-21-2009 | 12:42 PM
A lot of manufactures use "StarBoard" it's a plastic that can be cut/molded using regular woodworking tools.
Chico&Zeus is offline
