500hps  or Bulldogs >
500hps or Bulldogs
500hps or Bulldogs
Old 05-18-2009 | 07:37 PM
Default 500hps or Bulldogs
Hey Guys how can you tell if your 500's are Bulldogs or not by the serial number........ thanks
speedchangesyou is offline
Old 05-18-2009 | 08:47 PM
Bulldogs and 500's are two entirely different engines. The Bulldogs are 540 CID while the 500's are only 500 CID. The serial numbers should tell you what you have.
RaggedEdge is offline
Old 05-18-2009 | 09:41 PM
jeff32's Avatar
how many HP are the bulldogs ?
jeff32 is offline
Old 05-18-2009 | 10:30 PM
Merc rated them at 500 HP, same as the 500's. They were a stronger running engine though.
Old 05-19-2009 | 06:09 AM
Default Difference
So who do I call at mercury to find out? Any phone numbers?
thanks
Old 05-19-2009 | 06:20 AM
jeff32's Avatar
serial number plus your local merc dealer
jeff32 is offline
Old 05-19-2009 | 08:00 AM
birdog's Avatar
My Bulldog intake Manifolds have a 'TD" Cast after the brand Name..(tall Deck}
birdog is offline
Old 05-19-2009 | 08:08 AM
The intake manifolds on the Bulldogs are black, the HP500's
are blue.
The flame arrestors on the Bulldogs say Bulldog
Bulldogs have a carb spacer under the carb,
HP500's dont.
JaayTeee is offline
Old 05-19-2009 | 07:23 PM
Default bulldogs
Thanks Guys
Old 05-20-2009 | 09:13 AM
aTX427's Avatar
Get bulldogs if you can find them. They make the same power as the 500HP's, but will make a lot more power with a cam and heads.
aTX427 is offline
