30 Outlaw with twin 496HO's which props?
My boat is still stock with the original props. Any recommendations on a propeller change?
I have seen talk of "labbed props" What exactly is this?
Thanks for your time!
Your boat should have come with 28" Bravo 1's. You should be able to run a labbed 30" with no problem. Labbing is a process in which the blades are thinned, and balanced. That is the short version. In your case they can put a little cup in the tips for more bow lift. Call Brett at Bblades for more info. He can set you up right.
