oil pressure gages >
oil pressure gages
oil pressure gages
Old 05-20-2009 | 09:53 PM
johnnyboatman's Avatar
Default oil pressure gages
i have a new livorci oil pressure gage . the needle wont move if i pull the sender wire and run a wire to the sending unit it pegs? put a new sending unit in and it does the same what am i doing wrong?
johnnyboatman is offline
Old 05-20-2009 | 10:01 PM
You are grounding the sending unit !!! " WRONG "
1 wire to the gauge ,,thats it !! The sender gets ground from the thread !!
DareDevil is offline
Old 05-20-2009 | 10:05 PM
i aint grounding anything wire to sender, gages grounded to dash.
Old 05-20-2009 | 10:12 PM
mmmmmmhhhhhhh,,,bad sender ?! i guess !!
What kind of sender is it ? 1 or 2 terminals ?
1 say's G and 1 say's W ????
Then the G is GAUGE , i am not trying to be smart ,,but most think it means ground !
ALSO ,,,,,COULD THE WIRE BE DAMAGED SOMEWHERE ??
Old 05-21-2009 | 08:45 AM
the gage has a S which means sendor,g means ground
Old 05-21-2009 | 12:32 PM
offthefront's Avatar
DD is right ..... G means gauge .... W means Warning .....goes to a lamp ....m
offthefront is offline
Old 05-21-2009 | 12:37 PM
The only Ground on the gauge would be for lighting ....the Gauge is Gnd Through the sending units ......m
Old 05-21-2009 | 10:11 PM
whats it mean when the gage pegs, i tried a diff gage and it did the same thing, i bought new gages and am using a oriellys sender should i buy one from livorci .
Old 05-21-2009 | 10:38 PM
Normaly if the gauge is peged to max then something is grounded out and that could be at the gauge it self, Could be the wire from the sender to the gauge. look on the gauge it self some times the post for the ground will have ground signs with the 3 lines over each other ---
Boat Tech is offline
Old 05-22-2009 | 08:46 AM
Its A Twin Engine, The Problem Side Is Wired Like The Good Side. Im Banging My Head Against The Wall
