Dyno Time Any Guess HP >
Old 05-22-2009 | 09:56 AM
Default Dyno Time Any Guess HP
The motor goes on the Dyno Monday . It a 516 cdi Dart Heads 9.0 to 1 compression and a RM builder cam . Any guesses on the numbers on a 2006 dyno . This will be all motor no accessories.
Joby
formula 382 sr-1 is offline
Old 05-22-2009 | 10:00 AM
racinfever's Avatar
545 -----575hp
racinfever is offline
Old 05-22-2009 | 10:53 AM
Thunderstruck's Avatar
585 hp with a reasonable correction factor i.e. real atmospheric data input not hurricane eye barometric pressure.
Long time cult member.
Thunderstruck is offline
Old 05-22-2009 | 10:54 AM
With AFR heads and 9.6:1 I would predict 620 hp.
Old 05-22-2009 | 12:12 PM
570hp at 5400rpms.
Griff is offline
Old 05-22-2009 | 01:02 PM
The dyno will not let us change the weather station, It is what it is !!!!!!!!
Old 05-22-2009 | 01:06 PM
Originally Posted by Griff
570hp at 5400rpms.
We just dynoed two 516 EFI'S (hp500 EFI ) with 741 cams Merlin 320 heads 9.3 compression . One made 570hp the other made 582hp both at 5500rpm.
Old 05-24-2009 | 09:03 AM
What dyno equipment is the motor tested on? Tested to what standard?
ROTAX454 is offline
Old 05-24-2009 | 09:09 AM
Very realistic numbers. Now if you had stated 620HP or something, well that just puts a whole new paint job on things. What torque/rpm numbers did those motors produce?
ROTAX454 is offline
Old 05-25-2009 | 06:24 PM
It is a 2006 Stuska XS-211 with Power Pro 2.0
