500 EFI Problem
Old 05-22-2009 | 09:06 PM
Default 500 EFI Problem
I have twins Starbard motor after running one minute I lose fire and the motor cuts off
BOAT HAS MSD BOXS AND DISTRIBUTORS AND # 2 MSD LARGE BLUE COILS
Changed coils no difference
you wait about 3 to 5 minutes and the motor starts up and does the same thing
any advice
gnorthga is offline
Old 05-22-2009 | 10:23 PM
Default easy one
sounds like the msd box.... easy test....switch the boxes and see if the other motor cuts off....you could do the same with the coils.....its SO NICE to have twins.....good luck!!
onpointe is offline
Old 05-22-2009 | 10:25 PM
ive had SO MANY problems with msd stuff.... i drag raced for many years, all i will use is mallory intermetent problems blow
onpointe is offline
Old 05-22-2009 | 10:37 PM
already switched coils no difference going to try boes in morning what about the pic up and module inside the msd distributor
gnorthga is offline
Old 05-23-2009 | 12:17 AM
Default new one
Not so sure about the pickup...it is a possibility, as it does tell the coil to fire, but I've never personally heard of an intermitent problem with those... The fact that it starts back up and repeats says computer control mod inside msd box...
onpointe is offline
Old 05-23-2009 | 01:33 AM
Try to wiggle the pink wire that comes off the Dist. to the coil . We just had to replace ours on the 42.
satisfied1 is offline
Old 05-23-2009 | 10:01 AM
i agree,sounds like a bad box,but the pickup is cheap and easy to replace.i would change it anyway,then you eliminate the question of it being bad.
mike tkach is offline
Old 05-23-2009 | 10:20 PM
Thanks Guys It Was The Msd Box Up And Running 100+ For The Holiday
Oso Members Come Thru Again
gnorthga is offline
Old 05-23-2009 | 11:07 PM
I hate to talk bad about a product, but over the years I've ran into WAY TOO MANY funny little problems with msd products. I'm talking problems that stump GOOD mechanics.. Mallory or for most cars atleast, the stock stuff supports around 500 hp.
onpointe is offline
Old 05-24-2009 | 08:20 AM
Sounds like a winter project I might just have to look into
gnorthga is offline
