MSD BOX GM-2L getting no spark
If you try the test below and there is no spark ....replace the box ......
http://msdignition.com/page.aspx?id=3206
WAIT !!!! are you SURE ???? by god i have NEVER heard of an MSD box going bad...
this is shocking news.
alert the media.
msd ought to sell those things in pairs. one to get you halfway there and the second one to get you back home...
alert the media.
It's entirely possible that the new box is JUNK as hard as that may seem to believe. A few years ago my msd 6 box got dropped from about 5 feet onto concrete,it was 6 or 7 years old and still worked flawlessly up until this happened. I decided to upgrade to the marine box,the same one you have. The first one I ordered would only rev so hi even though the chip was much higher (it also did it with chip removed),would occasionally quit t of the blue. I sent it back andgot another,it was WORSE,had weird intermittent problems. I called Msd countless times,they kept blaming MY install. I rewired it and it made ZERO diffference. I then ordered a 3rd box AND a msd tester. Guess what,I immediately took the 3rd box out of it's packaging and hooked the tester to it,it was JUNK right out of the box (it would spark a few times if you had tester on it and wiggled the input wires alot!!! Disgusted,I sent everthing back and installed a crane hi box,it has been trouble free so far,Smitty
Darrell.
