Not sure what to do. >
Old 05-25-2009 | 05:28 PM
Question Not sure what to do.
Sorry to post this in two threads but thought the engine guru's might give some advice.
I am at a crossroads. I am in between prop. My engine made max HP and TQ between 5200 and 5300 RPM. My 26 non labbed Bravo can run asc high as 5600 RPM light. I ran a 28 Bravo non labbed yesterday very heavy 4 adults and a full tank of gas. I am seeing 4950. That said I typically run about a half tank and will pick up 150 to 200 RPM. Am I better off to be over HP range or were I am? And should I cup a 26 or cut down the 28? Any thoughts.
RBeyer is offline
Old 05-25-2009 | 05:51 PM
GO4BROKE's Avatar
I would have the 28 labbed to your specs. My boat runs 200 rpm's higher with lab 26" props vs stock 26" Bravo 1's
[img][/img]
GO4BROKE is offline
Old 05-25-2009 | 05:56 PM
Consider doing your prop testing with the same load and do the testing back to back on the same day. This will eliminate most of the variables....the rest is just a decision.
BenPerfected is offline
