Bravo I Drive won't go DOWN? >
Old 05-25-2009 | 06:46 PM
Default Bravo I Drive won't go DOWN?
One of my drives will not go DOWN.
Doesn't sound like the motor is operating, both (I have two drives 38KV Scarab) drives go up with the switches and with the trailer switch, just one will not go down.
where to start?????
JetJock is offline
Old 05-25-2009 | 07:19 PM
Down solenoid on that side is either bad or power is not getting to it for some reason.Is it clicking when you hit the switch?If it is try jumping a wire across it to see if the motor runs down.If it does then the solenoid is bad
picklenjim is offline
Old 05-25-2009 | 07:20 PM
EASY FIX!
Was the cannon plug connector, must have bumped it when doing the Oil change!
Everything works great again-thanks for playing now back to our normal program.......
JetJock is offline
Old 05-25-2009 | 07:21 PM
thanks Picklenjim! Went back out while you were responding and checked the connectors--talk about an easy fix!
I was about to call Tres! Saved him the trip and some gas money for myself.
JetJock is offline
