gear heads  help >
gear heads help
gear heads help
Old 05-28-2009 | 08:36 PM
Default gear heads help
woops, intended Formula forum but same applies
not my formula, but my old boat i am trying to sell.
89 454 carb engine
blows big time smoke out starboard side exhaust,
open pipes, not twined.
only after high speed run, then shut down and re start.
doesn't smoke without being turned off.
no blow by on crank vent in valve covers, either side
i am hoping valve seals on one bank.
waasss up
nsformula is offline
Old 05-29-2009 | 06:58 AM
If you do a leak down you can listen when the cylinder is pressurized to find where the leak is. Sounds like valve seals.
How many hours?
Wildman_grafix is offline
