575 SCI problems ???? >
Old 05-29-2009 | 11:58 AM
Default 575 SCI problems ????
anybody experienced any problems with there 575 SCI Blown Throttle body Injected 2001 ,running really rich -using lots of Oil ..fuel pressure is dead ballz on & no computer codes ..
thanks in Advance
Old 05-29-2009 | 12:25 PM
Default 575sci
Oil consumption I would look at rich condition causing a fuel/washout or worse a hole in piston depending on how much is alot? compression/leak test.
Rich condition can be several items but when I worked at GM we had some issues with the truck style throttlebodies merc used with 575's injectors failing, ohm test them or use a timing light to see the spray pattern.
Place to start.
Thumper
thumper038 is offline
Old 05-29-2009 | 01:19 PM
Linster's Avatar
Off the Radar
Not sure of what started the problem, but oil consumption and rich means it could have washed a cylinder or two. If the rings arn't sealing, it can eat a quart a day. I burnt a couple of pistons in the past and had oil everywhere outside the engine with a 3/8" hole.
Linster is offline
Old 05-29-2009 | 02:05 PM
How many hours on them ?
JaayTeee is online now
Old 05-29-2009 | 02:45 PM
Fresh 10 hours
Old 05-29-2009 | 03:12 PM
Originally Posted by RunninHotRacing158
Fresh 10 hours
Fu(k it. Start over. Tear em down and tell the guy he should have come to you first.
Sounds like more than 1 problem in there to me, but busted piston sounds pretty close. Is it blowing by.
jeff1000man is offline
Old 05-29-2009 | 03:35 PM
They do tend to run a little rich, especially when cold.
10 hrs. and using oil....something sounds f'ed up.
Jacked up rings or washed down cyls ??
Mine ran til 388 hrs before one of them lost a head
gasket, and either of them never used any oil between
change intervals.
I do remember someone on here having a
fuel consumption problem,( rich) and it ended up
being an unplugged I.A.T. sensor.
Old 05-29-2009 | 03:39 PM
change intervals.
If they were run really rich for more than a little while then they are frined anyway.
How does the oil smell. Does it have fuel in the oil?
Old 05-29-2009 | 03:44 PM
Default 575
Yea all that!!!
10 hrs under load can be very bad to a motor not running correct.
Old 05-29-2009 | 03:56 PM
change intervals.
she loses 1 quart of Oil an hour , may be leaking right out the oil cooler and straight out the tailpipe
Unplugged sensor i will check on
