Sea Strainer recommendations....
Well after my overheating problems with the seaweed, im thinking a sea strainer wouldnt be a bad option.
Is there any recommendations for my setup?
94 Baja 272 w/ 330hp Merc 454 and Bravo drive.
Thanks!
Pros and cons of different models would be great, as I have never used a strainer before.
Thanks!
Get something you don't need a tool to open. I got those for the MTI...
Hardin marine bought them through Keith Eickert Marine
http://www.keitheickert.com/detail.aspx?ID=8918
My boat was built with Marine Machine strainers. They are very solidly built units and I'd recommend them in a heartbeat. My years of experience with them tells me that it is critical to use a lot of anti-seize on the lids to prevent them from seizing up given that the buckets are Stainless and the lids are Aluminum. There have been threads here with some ugly pics of lids needing to be cut off. I had to cut mine off about 3-4 years ago. I had the lids off to clean them out and wiped off what I felt to be excess anti-sieze off the threads. Then I hosed down the bilge to clean it. The open spaces between the vanes on the lids trapped water which seeped down the threads and they seized up. Had to remove them which was awful in my boat and used a die grinder to carefully make two cuts in the edges of the lids to get them off. No problems since because I make darn sure I goop them up real good. This was entirely my fault. For what its worth....
Good Point - that is one drawback to mine is that you need an open end wrench to get them off.
Thanks - I am going to put some antiseize on mine next time I take the cover off.
http://www.livorsi.com/catalog/sea_strainers.htm
Very happy with my Livorsi sea strainer.
Definitely get one you dont need tools to open.
Chasing sockets and wing nuts in a dirty bilge is a bummer when your trying to get back underway.
Cant imagine boating without a sea strainer anywhere- there is so much crap everywhere these days. Lakes, ocean kelp beds it all ends up in there.
Uncle Dave
Uncle Dave
