I need a set of new or used #6 props ASAP!!!!!!!!! >
Old 06-02-2009 | 03:51 PM
Default I need a set of new or used #6 props ASAP!!!!!!!!!
I'm trying to get these props by this weekend.
16-1/2” X 33 or 34, 17 degree rake.
jason6116 is offline
Old 06-02-2009 | 03:53 PM
Tazz's Avatar
I've got a set of 17x32 if they'll work.
Tazz is offline
Old 06-02-2009 | 04:21 PM
throttleup's Avatar
What HP rating?
Julie
throttleup is offline
Old 06-02-2009 | 04:33 PM
Have a set of 16x32 5 blade would sell for a good deal.
Pro1 is offline
Old 06-02-2009 | 05:53 PM
I have a set of 16.5 x 33 just referbed by hering. perfect. 928 279 7806
scoop123 is offline
Old 06-02-2009 | 06:31 PM
Originally Posted by throttleup
What HP rating?
Julie
1200hp each
Old 06-02-2009 | 07:53 PM
throttleup's Avatar
I cannot stress this to you enough USED propellers are not the way to go! You need propellers that are of the appropriate engineered thickness. With a 1200 HP engine you should not run props without the appropriate thickness and never with props who's history is unknown. I would seriously recommend that you call us or someone in the business, to get the correct propeller for your application.
Julie
Old 06-02-2009 | 07:56 PM
^ what the hot blond lady said ^
DareDevil is offline
Old 06-02-2009 | 07:57 PM
Julie
Julie,
Can you provide new propellers by EOB Friday? I don't mind paying extra for new propellers. However, I need them this weekend!!
Old 06-02-2009 | 09:28 PM
Julie
I agree with this statement once you have your final destination. number 6 props are not exactly here ya go or one size fits all. Trying these props out to get your size is the only way to dial in. I liked the Herrings but they wanted to lift the boat much more then the Merc props on a 2006 32 Skater which has plenty of lift on its own. My buddies boat 2010 39 Nortech is also running merc props. I think the CNC props are pretty nice.
My point is if you can get the right prop through trial and error and then order the new set.
Pro1 is offline
