bottom turing yellow
So my unpainted bottom is starting to turn yellow. I use the boat for about 10 hours every weekend and after every use it goes back on the trailer, wash it, flush the motor,etc. The bottom is turning yellow and makes the boat look like crap. What should I do..just washing it with soap and water isnt even helping.
Erik
Erik
Mary Kate ON/OFF will clean it great....I cut the stuff with water and make sure you read the label. Do NOT get it on your skin and you'll need to wax the bottom after use of it will get just as yellow next time you put it in the water.
thanks
Erik
do NOT get the acid on yourself, or a galvanized trailer, it will take your skin and the coating on the trailer right off.
btw- I have tested waxing the bottom versus just acid wash- no difference.
Once the gel is pourous enough that it yellows like that its time to paint the bottom.
Erik
Erik
if u run it harder and faster it will stay white. haha
Erik
Erik
