Deadrise?.......... >
Deadrise?..........
Deadrise?..........
Old 06-11-2009 | 04:49 PM
Default Deadrise?..........
Hello all. I purchased my first offshore last year. I was wondering how deadrise is measured. What would be the technical term for the amount of the v-hull that rises out of the water in height. some boats seem to have a lower side profile and others seem to raise high out of the water in the front/bow. Thank you for your input.
moxxy13 is offline
Old 06-11-2009 | 05:03 PM
onesickpantera's Avatar
Deadrise is the angle of the V at the transom and is measured from horizontal.
I'm not really sure what you mean about the other question???
onesickpantera is offline
Old 06-11-2009 | 05:12 PM
The answer to your second question is freeboard!
endeavour32 is offline
Old 06-11-2009 | 05:18 PM
I kinda thought that too but the "raise high out of the water in the front/bow" threw me.
Old 06-11-2009 | 10:10 PM
I know what freeboard is.............I will try and find an example and post back...thanks
moxxy13 is offline
Old 06-12-2009 | 02:18 PM
While I still think you are thinking of lower stern freeboard and higher bow freeboard, perhaps you are thinking of "sheer"
Sheer is the upward curve or amount of upward curve of the longitudinal lines of a ship's hull as viewed from the side. While this is not usually common in performance boats, as most seem to have a fairly level deck height, this seems to fit what you are trying to say the most.
Philm is offline
Old 06-12-2009 | 10:04 PM
Thanks Philm......
moxxy13 is offline
Old 06-13-2009 | 12:18 AM
No problem man, hope this helps
Philm is offline
