Anyone removed the stops on there tabs on a 32 fever >
Old 06-15-2009 | 05:02 PM
Default Anyone removed the stops on there tabs on a 32 fever
I was wondering if anyone has removed these & if it changed the charecteristics of the boat pulling the tabs all the way up out of the water, only thing I could think these were installed for was to help prevent the boat from porpeissing(sp?) any other thoughts opinions?
jmoore1225 is offline
Old 06-15-2009 | 06:24 PM
We had a 1999 and removed them. I believe Reggie put the snubs on to stabilize the boat at high speeds.
fountainwoman is offline
Old 06-15-2009 | 08:45 PM
Reggie's Avatar
I had a 2000 with 454 mags. I took them off for faster speeds, put them back on when I wanted a better ride.
Reggie is offline
Old 06-15-2009 | 09:47 PM
Well I planned to mark exactly where the stops would let them go up to, I was just wondering how the boat acted with them off and raised all the way up, does the boat tend to wanna porpoisse again(sp?) with them raised all the way up, what's the difference in speed #'s
Old 06-15-2009 | 10:43 PM
I don't have them on my 2000, but US1 has them on his 99.
I believe they are set for neutral, on mine if you raise the tabs above neutral you don't gain speed but it chime walks BAD.
Wildman_grafix is offline
Old 06-15-2009 | 10:52 PM
They prevent from chine walking ,,,but u will run faster with out them,,,,,maybe 2 MPH ,,very unsafe tough....unless u have big kahunas !! If the boat is fast enough u can drive thru the chine walk and it will become quite again,,but it takes guts and knowledge.
DareDevil is offline
Old 06-15-2009 | 11:29 PM
I took them off my 27. No real big dif. The tab inicators are there for a reson. to see where the tabs are. The stops would be good for ocean racing where you can't always fine tune. My chine walk goes away at 74 MPH or so.
mcprodesign is offline
Old 06-16-2009 | 02:24 PM
I removed the trim tab stops on my 1998 32' Fever. It did not change the speed at all but it did change the handling. It required a little effort to keep it balanced at top speed with the stops out. My boat ran 80 mph on the GPS. With the tabs stops in you could take your hands off the steering wheel at WOT but with them out, you had better keep your hands on the wheel.
convincor253 is offline
Old 06-16-2009 | 04:54 PM
Sounds like they are there for good reason!!! Looks like I'll just leave em alone thanx guys
Old 06-16-2009 | 09:48 PM
blume's Avatar
take them off and cut about 1/4 inch off and put them back on.
blume is offline
