What year are my motors? >
Old 06-17-2009 | 09:17 PM
Default What year are my motors?
I have a 88 scarab III with 454's and when i bought it the guy said it had new crate motors installed in 2005 so im wondering what i have to do to find out what year they really are. Any help would be great.
tscarab88 is offline
Old 06-18-2009 | 01:22 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default motors
Do they have a place for manual fuel pumps to bolt on.JOHN
Fenderjack is offline
Old 06-18-2009 | 01:56 AM
You could try Looking right above the starter there might be a tag with the serial number on it. Then call a dealer and have them run the history for you.
Boat Tech is offline
Old 06-18-2009 | 07:36 AM
you can get the #'s you need to ck on the pad that sticks out from under the left head as you face the engine, clean that off and the #'s should be there unless the block was decked..
ezstriper is offline
Old 06-18-2009 | 10:54 AM
When you find the number go to mortec.com it will tell you what you want to know. If it has a place for a manual fuel pump it is a Mark IV. If it has no place for fuel pump and a metal cover Gen V, a composite timing cover it is a gen VI.
jeffswav is offline
Old 06-18-2009 | 11:05 AM
Ok great I will get the numbers and check that out, Thanks guys!
