HELP! Need size for hydraulic steering fittings >
Old 06-19-2009 | 09:05 AM
Default HELP! Need size for hydraulic steering fittings
I know I should of just grabed the lines and take them up to the store, but the boat is out of town and I need help figuring out what size fittings I need. Here is a picture, basically were having to run some 45* fitting adapters to get our bellhousing mounted oil coolers to fit. So we need to replace the 4 straight fittings for some 45*'s, but I don't know the size. Any help would be greatly appreciated. They are for the center hoses (orange).
Attached Thumbnails HELP! Need size for hydraulic steering fittings-apache-bilge1.jpg   HELP! Need size for hydraulic steering fittings-apache-bilge2.jpg   HELP! Need size for hydraulic steering fittings-bilge3%2520%2528large%2529.jpg
TexomaPowerboater is offline
Old 06-19-2009 | 09:49 AM
They look like #6 size which is about 3/8". But it is hard to tell by just the picture.
niceguy is offline
First of,,,u need 90's and T's,,,size ??????????? They are all diffrent.
DareDevil is offline
Old 06-19-2009 | 10:00 AM
Rookie's Avatar
My system uses #6 with 1/2" hose 3/8" NPT where threaded. It looks like you have 3/8" hose with #6 fittings.
A little off topic, but where is the best place to get the thru hulls for hydraulics? I need 4 of them.
Rookie is offline
Old 06-19-2009 | 10:06 AM
Here is where I'm at now. Why 90*'s?
Attached Thumbnails HELP! Need size for hydraulic steering fittings-installed4%2520%2528large%2529.jpg
Old 06-19-2009 | 11:43 AM
Default Fittings
The Hose You Have Apears To Be Size #6 (3/8). The Picture Of The Cross Over Hose That You Have Run Shows That Those Lines Will Fail Do To To Tight Of A Bend Radius. We Also Have Thru Hull Stainless Bulkheads In Size #6.
Jb-fse is offline
Old 06-19-2009 | 12:13 PM
Rookie's Avatar
Whose we??
Rookie is offline
Old 06-19-2009 | 12:20 PM
Because it looks cleaner and its press. so it will not restrict anything.
The 45's will still stick out,,why would u want to do that ??
+ u don't need to bend the hoses ,,which is not good for them.
Just me !
Attached Thumbnails HELP! Need size for hydraulic steering fittings-dd-003.jpg
Old 06-20-2009 | 09:48 PM
Andy here is a picture of a Hustler.........u see the 90's very good.
WORKS FINE !!!
Attached Thumbnails HELP! Need size for hydraulic steering fittings-90s-steering-over-exhaust.jpg
