bumping up rev limiter on 500hp >
Old 06-21-2009 | 01:35 PM
Default bumping up rev limiter on 500hp
500hp carb motors stock distributer and rev limiter i have msd boxes how do i unhook the stock rev limiter and then i can get a add on to my msds with a rev control that i set where i want.
rssteiny is offline
Old 06-22-2009 | 08:22 AM
any one know what wires to disconnect
rssteiny is offline
Old 06-22-2009 | 09:32 AM
Smitty's Avatar
I think it is built into the stock ignition module. But possibly it may be piggy backed next to it and maybe you could just unplug it and use a jumper wire ???
Smitty is offline
Old 06-22-2009 | 03:15 PM
Its burned into the computer I believe. I sent mine to whipple to be reburned from factory 5350 to 5600 upon whipple install
Chris, hp500efi 2002
elise909 is offline
Old 06-22-2009 | 03:25 PM
MIne is carberated no computer just the stock module.
rssteiny is offline
Old 06-22-2009 | 04:15 PM
It depends on what you have. On my 525SC with a TB IV ignition, there was a separate box that was the rev limiter. You could just get a standard 454 mag wiring harness that goes from the module to distributor and eliminate it.
It will depend on the serial number for your engine and what ignition you have.
If you have this set up, you can do as I said.
http://www.mercruiserparts.com/Show_...RU+0F877722%29
Griff is online now
Old 06-22-2009 | 04:34 PM
That does not look like my setup
rssteiny is offline
Old 06-23-2009 | 11:57 AM
2 wires coming out of distributer, going into a wire loom harness, so i assume the module is in the distributer and i do have msd boxes as well.
rssteiny is offline
Old 06-23-2009 | 12:16 PM
Yours must be this one then. I think the rev limiter is built into the module then.
http://www.mercruiserparts.com/Show_...RU+0L001772%29
Griff is online now
Old 06-23-2009 | 01:28 PM
My msd wires are red and white going back to a purple and gray wire ,, there is also a capped off purple w/ white stripe.
my dist wires are white w/ red stripe and white /w green stripe.
coil wires are orange and black.
if this helps at all that is what i got.
rssteiny is offline
