04 26 ao Fuse Panel?
that year should might have circuit breakers which have resets either above or below the switches... if it has fuses they should be right there also. send me some interior shots of the boat and the switch panel and I can see if it jogs my memory..
[email protected]
Don
[email protected]
Don
we used several different configurations. most 2600 s had circuit breakers with reset buttons located in the switch pannel on the dash. the fuse for the hatch openers was located under the drivers seat. mercury motors have a 50 amp circuit breaker located at the rear of the motor adjacent to the ECM. it is a red button. the starter motor wil not work if this circuit breaker is not reset. also the shifter must be in neutral because of a neutral safety switch built into the shifter. the bilge pumps were hot wired in and not protected by a fuse. the only place we put fuse pannels was behind the dash when we did not use the circuit breakers in the switch pannel.
Thanks for the info that helps.Boat is not a nxs I bought it from shrogren this past winter.Motor is a blown 540 Joey Griffin built whatever thats worth.Anybody know the boat?
