Weird electrical problem
I just this week replaced two engines for a friend in his four winns. it has 2 350's with volvo outdrives. the engines were salt water with no proper flushing done. it is a 2000. anyways i installed the engines. and hooked everything up. I cant get either to crank. i have power to both starters. the court lights are on dim the switch is not on. the blower switch lamp is on and the switch is not on. it seems like the thing is trying to find a ground. what did i do?
[QUOTE=Fixxxer22;2897931]battery 1 ground to engine star.. battery 2 ground to engine star. ground between port and star.[/QUOT
Ok???? where on the engine ??
Put the shifter in neutral !!!!
not being a smartass,,,, done that after engine replacement.
and to add insult to injury,,,, im out there with a meter and schematic,,,,, wife walks out,,,,, hey,,,, doesnt that lever thingy have to be straight up !!!!!???
GO AWAY WOMAN !!!!!!
tunnel vision sucks !!!!
KISS ( keep it simple stupid )
starting system is very simple,,,, trace power from starte solonid back to the keyswitch,,,, if you have it,,, like they said,,,, you missed a ground somewhere,,,,, whenever I pull a motor,,,,, I take all the grounds and tie them together with a small zip tie,,,, this way when your laying in there setting the motor in your not hunting for them
I want to live in a world where a chicken can cross the road and not have its motives questioned.
that is the problem. the boat used to be in salt water and it took on water once. everything is a rusty mess. the ground studs are rusty. Should i just re-locate to the heads? with new clean bolts?
Jump the starter solenoid to the main +12v going to the starter to see if it cranks that way.
Had an old boat that we had to do that to start it, out running around and the damn starter wire broke. Nothing like laying on a hot exhaust manifold trying to hotwire the damn thing
