bravo 1 lost forward gear >
Old 06-28-2009 | 10:49 PM
Default bravo 1 lost forward gear
I was just cruising when i heard a terrible grinding noise and then lost forward. I had to backup nine miles to the trailer. What the heck happened? I have about 150 hard hours on bravo 1 and about 550 hp.
tmbl52 is offline
Old 06-29-2009 | 12:16 AM
articfriends's Avatar
99% chance you broke the floor out of the forward drive gear,I have done exactly what you are describing,including the backing up for 8 or 9 miles,Smitty
articfriends is offline
Old 06-29-2009 | 10:47 PM
how many dollars. I hate spending money on things that dont help it go faster.
tmbl52 is offline
Old 06-30-2009 | 12:32 AM
If your drive is a 1998 they no longer make a replacement gear for it,what merc sells is a upgrade kit with xz gears with a thicker floor,the kit also comes with most the bearings and parts needed to covert it. Expect to pay about 2000$ for the gear kit and labor to install it (assuming the tower in your upper is still good). The lower should be examined too for debris and damage,Smitty
Old 06-30-2009 | 09:53 PM
i just pulled the drive cap and found lots of metal. ick. might be an early end to the season. Is 550 hp too much for that drive or is this fairly common? I am always hammer down every time i take off. maybe thats it
tmbl52 is offline
Old 06-30-2009 | 10:52 PM
obnoxus's Avatar
Charter Member #1171
Originally Posted by tmbl52
i I am always hammer down every time i take off. maybe thats it
that and wave hopping are the 2 biggest Bravo killers
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-01-2009 | 12:04 AM
Poker&Run's Avatar
When I was at 550hp, I usually got around 50 hrs on a bravo 1. Upper Gear set, bearings, and race for that unit lists for $2011.00. I would recommend going to an XR or your will be visiting this scenario pretty often. All it takes is one blowout on a big wave and you will be facing the same problem again.
These boats don't steer too well in reverse (as I am sure you now know!)
BEING KOOL AIN'T CHEAP!!
Poker&Run is offline
