engine coupler >
engine coupler
engine coupler
Old 07-06-2009 | 11:19 PM
Default engine coupler
If I have the engine coupler with the snout, do I have to replace it with one with the snout?It seems all the ones I can find do not have the snout.
Bravo application.
tx911 is offline
Old 07-07-2009 | 12:37 PM
noone knows?
tx911 is offline
Old 07-07-2009 | 12:42 PM
I din't know they made one without the snout for a bravo application.
Are you sure you aren't accidentaly finding one for a transmission application?
jeff1000man is offline
Old 07-07-2009 | 05:19 PM
You can use either coupler. They are interchangeable. The long snout steel one is listed as OEM for the 575SCI and you can look it up that way on www.mercruiserparts.com.
Griff is offline
Old 07-07-2009 | 06:52 PM
fastedy's Avatar
Griff, I just put an 2001 hp500efi in my 2005 Superboat, I used a coupler with the longer snout and had a vibration but ran it anyway this weekend, Just pulled drive and vibration still there, sound like the snout is lightly touching the transome plate where the snout goes in, alingment tool still goes in freely (one hand slight push) is this possible?
Thanks in advance for any help I can get,
Eddie
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 07-07-2009 | 08:48 PM
thanks griff
tx911 is offline
Old 07-08-2009 | 02:01 AM
Eddie
I don't think so. I switched from the standard to long snout on my 525sc and never had an issue. Maybe the coupler is bad and out of balance??????
Griff is offline
Old 07-08-2009 | 07:25 AM
fastedy's Avatar
going to pull motor thursday and change coupler, Ill post what I see
Mario Andretti
fastedy is offline
Old 07-12-2009 | 07:08 AM
fastedy's Avatar
Cut if off with sawzall (sp). Vibration gone, once if found out the snout was aluminum it was easy to cut
Mario Andretti
fastedy is offline
Old 07-13-2009 | 01:59 AM
I didn't even know they made long snout aluminum ones. Mine was steel.
Griff is offline
