Raw Water Pump ? >
Raw Water Pump ?
Raw Water Pump ?
Old 03-30-2002 | 09:03 PM
SR-24's Avatar
Default Raw Water Pump ?
Hey guys, I'ts been a long winter. I can't remember if your incoming hose goes on the top inlet/outlet or the bottom. I have the raw water pump that 90's in towards the motor instead of running straight back. I have it on the top right now, but I wanted to check before I started it.
SR-24 is offline
Old 04-01-2002 | 07:04 AM
Iwould try to see if it is indicated on the pump housing near hose nippels. If you can't get in there take a small mirror and shine a light on it.
I'll bet it is marked.
TomR is offline
Old 04-01-2002 | 10:49 AM
Dont believe anyone that tells you its either the top or bottom. The pump can be rotated on its bracket. It will be marked on the back inlet /outlet for either standard or reverse rotation.
Gary
Gary Anderson is offline
Old 04-01-2002 | 12:43 PM
SR-24's Avatar
Thanks guys!
SR-24 is offline
Old 04-01-2002 | 07:48 PM
blue thunder's Avatar
Been workin this problem my self tonight. Turns out standard is left hand (lh) rotation. LH out goes to oil cooler, RH out is intake. Hope you have better luck than I am having on this crappy job.
BT
blue thunder is offline
Fenderjack
3
01-12-2008 02:55 AM
jdub
7
03-26-2007 05:06 PM
CHAOS REIGNS
1
06-20-2005 10:10 AM
StrikinLightnin
5
08-15-2002 09:04 PM
SR-24
03-31-2002 07:51 PM
